Hi all...hope you're all well
I'm on the verge of casting aside the ruinous run flats and engaging some Michelin PSS goodness instead. I live in the middle east though, and don't like the thought of being stuck on a desert road in the middle of .... well, the desert ... with a flat and no spare and just a can of gunk.
So I've been looking around for a space saver spare and found this:
http://www.bimmerzone.com/BMW_Performance_Spare_Tire/BIM-SST-E89-KIT.html
Thing is, it says it's for 20i, 28i, 35i...but that it's NOT TESTED WITH 35is or M sport brakes. Which is of course what I've got (at any rate, I have the 35is car...whether it's got M Sport Brakes or not, I don't know how to tell).
I guess the stud pattern and the overall tyre diameter will be the same as the 35i. So the only thing I can think of that might be an issue is if the brake rotor or calliper on a 35is a different size to the 35i since they have tested it with a 35i?
My car is a standard 35is, but with the 19" 326M wheels.
Any and all help would be appreciated
Thanks,
J.
Thanks,
J.
