Jimmy Gee said:davidro said:Which is the best piece of foam to remove on the 3.0si? The piece closest to the cabin or the piece closest to the generator/engine? Which one is the biggest piece?
thanks guys
If its the same as the 3.0i then the biggest piece is at the bulkhead end.
The 3.0si sound generator is a completely different design to the earlier models. It seems to have additional resonating chambers and is fixed to the compartment using different clips.
Someone mentioned that they took out a piece of foam at the engine end of the tube and it made no difference on the 3.0si. Just wondering if anyone else has done this on a 3.0si and which is the best piece to remove?
