Sorry for being petty-
andysat
Hi all-is it just my pc or is anyone else slowly losing the home, forum, gallery, shop, etc from the main page?
I have this problem on my work PC, but not home on mac or PC. Might be your browser version maybe?
Yes I am experiencing this too on my laptop - the contents in the top menu red strip is not fully visable. You are unable to see what any of the menu links are. On my big 22 inch monitor though it shows up fine, as long as the screen is fully maximised.
I have just tested and when the screen is not maximised the links in the top menu will still show but only to a certain point as long as the window is quite wide. If you reduce the window width down (using the mouse cursor) evenually you reach a point where the text/contents in the menu all moves down one line. It appears to be linked to the advert in the top - at a certain width or below the advert appears to push the whole menu contents down slightly. Sounds like a small css (web design) size issue.
ps. I have tried both IE7 and IE8 and same applies.
I have the same isues at work due mostly to using obsolete versions of IE.
At home all is good on my iMac...without IE... :thumbsup:
Been fine all day now it is happeing to me,i'm using IE8 on XP added a link so you can see the problem:idunno:
http://www.z4-forum.com/forum/viewtopic.php?f=2&t=18531&p=267033#p267033
Edit, now it's back to normal :-?
I am doing a few tweaks to try and fix things. Problem is I am working on a Mac and it seems to be Windows/IE users having the issues. Would some of you mind posting screenshots of what you are seeing so I can try and get a handle on it?
andysat said:
Cheers chaps(spe3ctre-i meant slowly- gradually losing a bit more over the past couple of weeks)-thanx again!!!
LOL, no worries... I think I will need to re-code the whole header to fix this... at least everyone can see the menu, even if it doesnt look right in all browsers.
Hey sp3ctre - mine's been perfect until whatever you did this evening.
Lost most of the menu buttons (new posts, search, etc.) underneath the maroon Z4 banner
Please can everyone let me know what OS/browser you are using. Kinda hard to pin this down at the moment...
