buzyg said:Looking quick and 8) . Time for a Cornish run out.![]()
Player 1 said:Cheers! Some good info there Peter, I did the service at an 8000 mile interval however will look into doing it every 6000 as oil and filter takes about 30 minutes and doesn't exactly break the bank.
Regarding traction, the Pirelli P Zero runflats were appalling, in dry conditions after remapping they could only just handle full throttle in third. As all we get here is rain and they were becoming downright dangerous if not careful, I ditched them after about two weeks for a new set of Goodyear Eagle F1's as they were always superb on my old car.
In a straight line it'll now put all the power down in second in reasonable conditions so cant complain whatsoever![]()
The torque is what's really been an improvement after the remap though, 3000 - 4250 rpm is now a solid 400 ftlb so anywhere within that rev range and it'll really take off, you're probably right regarding the N54 having enough power already but I've has a string of cars that handle like they're on the proverbial rails so fancy something with more power than grip for a change hehe![]()
Peter-E36 said:Sounds good, I've just bought a set of eagle f1s to put on the e85, they're going on today hopefully!
I fitted a Quaife LSD to the 335i which made a huge difference, so much more grip but you can still have your fun whenever you wanted and it played very well with the factory traction/stability control. Would recommend it but I'm aware it's pricey enough so hard to justify if it's not something you really want. It's great that you got a manual, you don't have to worry about the gearbox as much when upping the power![]()
step_change said:A much improved car that is much more comfortable with far fewer rattles and squeaks.
Peter-E36 said:Do frequent oil changes ... every 6k ...
Busterboo said:Peter-E36 said:Do frequent oil changes ... every 6k ...
Modern lubricants don't need to be changed so often, hence BMW's wide service intervals.
Peter-E36 said:Busterboo said:Peter-E36 said:Do frequent oil changes ... every 6k ...
I would still do frequent oil changes on an N54 as they run a lot hotter than other engines (normal operating oil temperature is around 120C and even higher if you're spanking it), and with the turbos using the same oil for lubrication - it's just not worth the risk.
I think BMW's service intervals are a bit ridiculous in general to be honest, and is partially responsible for the likes of the chain issues on the 2.0d engines, since everyone who had the chain issues and got replacements were recommended more frequent oil changes.
Just my 2c![]()
Busterboo said:Peter-E36 said:Busterboo said:Modern lubricants don't need to be changed so often, hence BMW's wide service intervals.
Just my 2c![]()
There's no evidence that the N54 Twin Turbo needs changes of BMW's SAE 0W-30 Longlife-04 more frequently than scheduled.
But, if it makes people feel better ...After all, that's what the Z4's for.
Busterboo said:As I said, if it makes you feel better ...![]()
jamie_z4 said:Don't feed the troll guys. I think he gets off on it
Ducklakeview said:jamie_z4 said:Don't feed the troll guys. I think he gets off on it
Yup, he'll be telling us next that running 45 psi in our tyres is good for the car and it's handling. Wonder how often he changes the air in his? Certainly no shortage of a hot supply..
Oh wait.. Dejavu moment there![]()
Mike
