SOLD: Back box bypass/delete - 3.0Si - Photos
Fred42
Following some very kind help from Machine Monkey I now have a back box delete pipe, tips and clamps for a 3.0Si.
Ready to go straight on. I'll get some photos up tomorrow.
Pro: Sounds good around town and pops and crackles during a blast. If it was a weekend car I'd have kept it on.
Cons: Drone on the motorway and as I'm using it to commute I have swapped back to the original.
Looking for £60 posted.
I'm in Winchester if anyone wants to collect.
Thanks.
Fred.
Also might be interested and I'm local too, Romsey way. Pictures please. Do you need to cut the pipes to put this on?
Yeah. Need to cut the pipes. Not sure of the technical term but the new pipes slide on and use the clamps supplied to tighten it on. It uses the same rubber mounts as the OEM exhaust.
I'll get some photos up tomorrow which should help in my explanation.
Some photos. Let me know if you need anymore.
I will add my opinion on this.
It did sound really good.
Easy to fit yourself if you have axle stands a bit of knowledge and an angle grinder reciprocating saw.
Build quality was very good
And it fits straight into the factory exhaust mounts.
You will just have to be carful cutting in the right place. And have some exhaust paste.
Machine monkey said:
should do i am fairly sure the diameter of the the exhaust pipe on all facelift 6 cylinder cars is the same. :thumbsup:
Is it tight, or can the pipes be cut with a exhaust cutter?
Never used these but i am sure they would work.
The exhaust on the z4 is stainless steel so may take more cutting than a normal steel system.
Its not really the length or cutting it i was referring to. But the diameter. witch i believe is the same on all z4s apart from the 2.0. witch might be the same diameter but only has 1 pipe.
well if we think it will fit then I'll have it, as been looking at getting done in next couple of weeks anyway, so would make it easier if its a straight fit on...unless anybody else on here can say otherwise?
could you PM me to sort it out please..... :D
can anybody confirm if this will fit the 2.2?....it looks like it will to me, as the bore looks the same.....?
I can't give you a 100% yes buddy that's part of the trouble with buying second hand stuff off a forum? You will have to take a punt on this at a good price or pay full price and get one customs made.
But I am quite sure it will fit! If not and you can get to ox28 and grease my palm and I will make it fit for you.
jpvd said:
hi monkey
Have you still got these?
if so can you PM me please....
cheers
paul
Hey they are not mine they are they are Fred42 to sell. I have seen them and heard them before I took them off. Look great quality and it sounded great pm the op
