I spent a long time looking for the right Z4 before finally buying this one. But with a wife, three kids and a big dog it was never going to get a lot of use. The time has come now to admit that somebody else should get the chance to enjoy it.
In excellent, well-maintained condition, and backed up with an extensive and detailed service history, this is one of the most well sorted Z4's in the country.
Despite looking standard it has some sensible under the skin improvements which take it well beyond its original capabilities:
The combination of the Koni dampers and Quaife LSD completely transform the ride, handling and grip of the car. To take advantage of this and the other modifications the car is running a MHD Stage 2+ ECU map (currently 420bhp, but can also be mapped back to stock at 305bhp). The original downpipes and intercooler are available if you wish to take the car further back to stock.
Remapping is an easy process - it can be done from an app on your phone in about 2 minutes. As well as remapping, the app also includes options to change other parameters such as exhaust valve, throttle response, idle - and will also read and clear standard OBDII engine codes.
In addition to greatly improved performance the car has had some upgrades to the interior. The steering wheel has been re-trimmed with beautiful perforated nappa leather. The factory speakers have been upgraded with BMW specific tweeters, mid-range and woofers from Hertz and Match. The original pop-up i-Drive screen has been replaced with a seamlessly integrated aftermarket touchscreen. As well as being a much clearer display this has the advantage of keeping the original i-Drive interface, but also integrating Apple CarPlay & Android Auto. The original pop-up screen is also available.
The car has been recently serviced and had new injectors, plugs, coils, various bushings and other preventative maintenance (including a salmon relay for the roof control unit - if you're looking for a Z4 make sure this has been done!). The alloys are unmarked, and the rear recently had new brake discs, pads, and a set of Michelin PS4's. The car also comes with the original silver grills, factory wind deflector, x2 keys, original owners pack and a folder full of invoices and receipts.
Car can be viewed in Livingston, Scotland.
- Quaife ATB limited slip rear differential
Koni Special Active dampers
VRSF downpipes
Mishimoto intercooler
Masata chargepipe
Burger Motorsport Dual Cone Intake
