Solar Trickle Battery Charger
birdy_z4
 Warwickshire
Has anyone used a solar trickle battery charger to boost the Z4 battery
I was wondering having got the fuse box out to fit my dashcam and tracker, whether to connect to the charging points in the engine compartment and feed a connection through to the dashboard to enable charging rather than in a socket.
Something like
https://www.amazon.co.uk/Waterproof-Automotive-Motorcycle-Powersports-Snowmobile/dp/B07DFD3RMS/ref=asc_df_B07DFD3RMS/?tag=googshopuk-21&linkCode=df0&hvadid=218093857332&hvpos=&hvnetw=g&hvrand=3419471447992593642&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1006494&hvtargid=pla-527738708323&psc=1
I stick a solar charger on wifey's 2.5i if we leave it more than a few days.
To be honest I don't think they have the capacity to put charge back into a battery, but are good enough at keeping it at the level it is when they get connected.
If you have a garage, car port just buy a proper solar panel around 100w and mppt charge controller then simply connect to your charging terminals under the bonnet.
You can run the cables along the inside edge of the headlamp, close the bonnet and lock the car.
Any recommendations for kit to do this please? I’d like to try but not sure what to choose from what is out there!
I use a company near me in Plymouth called batteries and solar. Check their website for kits and call them for advice. It is an incredibly easy thing to do. Panel comes with mounting brackets and around 2 - 3m of cable. You just connect the panel to the moot controller and the controller straight to your battery. .
Thanks the 100w are quite expensive so considering a 20watt
https://www.amazon.co.uk/dp/B07TY3HGF7/ref=sspa_dk_detail_3?psc=1&pd_rd_i=B07TY3HGF7&pd_rd_w=RrkQm&pf_rd_p=8d6f1b33-e9e1-48a7-9bf6-fb23b68a35eb&pd_rd_wg=qfJae&pf_rd_r=A9MY044W4BDV0BG23X0V&pd_rd_r=b64b2290-7d87-4cd7-ad55-5d4e0c1a28e0&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzOVpOTkRNUDM2N0w4JmVuY3J5cHRlZElkPUEwMjgwMjUyMVZRSFJWWFFUWU5HUSZlbmNyeXB0ZWRBZElkPUEwNTI0NzA3M0Y4QzZIMzhNQzIzUiZ3aWRnZXROYW1lPXNwX2RldGFpbCZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=#descriptionAndDetails
or
https://www.amazon.co.uk/POWOXI-20W-Solar-Panel-Controller%EF%BC%8C/dp/B07X7NB7YT/ref=sr_1_71_sspa?adgrpid=53268641036&dchild=1&gclid=EAIaIQobChMI0cO567np8AIVwoTVCh3NOQDsEAAYAiAAEgJEMPD_BwE&hvadid=259058752011&hvdev=c&hvlocphy=1006494&hvnetw=g&hvqmt=b&hvrand=5677171894326150223&hvtargid=kwd-316403440688&hydadcr=5116_1827870&keywords=solar-powered+car+battery+charger&qid=1622104745&quartzVehicle=29-10519&replacementKeywords=solar-powered+car+battery&s=automotive&sr=1-71-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFLRTlITkJENFpDVk4mZW5jcnlwdGVkSWQ9QTA4Mzc1ODAxRFo2NFhFNFhKSTZDJmVuY3J5cHRlZEFkSWQ9QTA5MDgwMjkxWUczMDhMTFM4NTQyJndpZGdldE5hbWU9c3BfYnRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
or
high quality and a lot more powerful https://www.batteriesandsolar.co.uk/shop-categories/solar-panel-60w-12v-poly-545x668x25mm-series-4a/
Thanks, much appreciated. Taking a look.
I bought this came in about two weeks.
https://www.aliexpress.com/item/32724195848.html?spm=a2g0s.9042311.0.0.3a5f4c4dRSn30H
fits to inside of windscreen and the cigarette lighter socket.
Isn't the socket disconnected when ignition is off? Mine is.....
The cheap ALDI variety has worked really well over the last 3 summers - over the last winter from October to April, you could tell on startup it could have been better
I suggest either a total battery disconnect (with subsequent clock & window reset), or find a home with power in the garage for a Ctek
Uk e85 lighter socket remains live, e89 shuts them down.
