Softtop Roof Hydraulic Pump
Z4bes
New member
Hi
I have taken my roof off to look at the motor as it wouldn't open from the close position (roof down to roof up). The motor was spinning but i had no hydraulic power, after testing once roof off, i worked out the problem was the brass fitting that the bowden cable moves when pulled it looks like the fitting hasn't not got the pressure/spring back required to allow the hydraulic pump to work. I took the bowden cable fitting off the pump and it worked fine, but stopped when the brass fitting was pressed. Is the hydraulic pump easy to strip and repair?
cheers
J
