hello I have a problem with the soft top of my z4 e85 after changing the limit switch (opening) sensor the soft top does not work anymore you lower the windows you hear the relay click but the soft top does not move the switch in the trunk and ok. I tried to put the sensor back (changed only because it did not stop the motor at the end of the stroke) but it no longer works even with that .... from the diagnosis it marks me short to the ground .... any idea? thank you
