Thus, on this basis, one is led to the inescapable conclusion that the ‘best’ E89 to buy is the 28i 8-speed auto…and, as Valencia Orange with its unique interior is aesthetically the best…then, I have just bought the best E89 to buy!N20 has more torque over a much wider range..the nominal hp advantage occurs at the top percentile…
Area under the curve is the hall mark of street based performance..
N52 2.5 is a peaky critter compared to the bulldozer N20
On anything but a racetrack the N20 would leave it in the distance…30i would be much tougher…in the same way the 28i leaves the 30i behind…especially with the 8 speed auto boxes…
At a perceived risk level against a wide range of road conditions the ability to carry a certain speed..bends, bumps, straights ..combinations there off..What does ‘handling’ mean in the land of Scots ?
Yup a later N20 or an earlier one with cam chain issue addressed and hopefully with better than bmw specified oil changes in auto is a great car…Atacama Yellow MSport of course is the definitive version..Thus, on this basis, one is led to the inescapable conclusion that the ‘best’ E89 to buy is the 28i 8-speed auto…and, as Valencia Orange with its unique interior is aesthetically the best…then, I have just bought the best E89 to buy!
(P.s. once I have spent the extra to upgrade to 2015 spec!)
Mine is 28i MSport Auto and has had services (mainly BMW main-dealer) always well ahead of BMW scheduling. I’m not driving it atm, as I wish to have the timing-chain, water-pump and thermostat and HPFP replaced first.Yup a later N20 or an earlier one with cam chain issue addressed and hopefully with better than bmw specified oil changes in auto is a great car…Atacama Yellow MSport of course is the definitive version..
wasn't that the one with the black roof? I'm sure one of the E89 encyclopaedias will be along shortly to confirmWas it not called 'pure traction' or something like that? Seem to think it came with a really good looking metallic weave on the metalwork pieces around the
Agreed, though the normally aspirated engines do sound better/nicer especially at those peak rpm’sN20 has more torque over a much wider range..the nominal hp advantage occurs at the top percentile…
Speak for yourself, old bean.At a perceived risk level against a wide range of road conditions the ability to carry a certain speed..bends, bumps, straights ..combinations there off..
Next you’ll be telling me that oiling the external side valve push rods is character building..Agreed, though the normally aspirated engines do sound better/nicer especially at those peak rpm’s![]()
So a bit at a time..Some 35i have adaptive dampers so I'm not sure the logic works that 35i DCT is always cheaper to maintain than 35is.
30i non-msport is possibly the worst handling car I have ever owned, the 35is was much, much better in corners. I'm curious why you've judged 35is handling to be so much worse than all other variants? Is that perhaps influenced by your personal disappointment when you bought yours? The engine is only a little heavier than the N52, and the adaptive dampers are much better for handling than SE. Personally I think you overstate the effect of engine weight in handling; 50kg (even if it's over the front wheels) in a 1,500kg car is not something many would notice. 35is has weight distribution of 49.3 front and 50.7 rear, so if anything it's more balanced than the smaller engine variants. Some people prefer more rear bias, but that's horses for courses and it isn't objectively "better". A Lotus Elise is heavily rear biased, a BMW M3 is around 50:50, and a modern Civic Type R is heavily front biased - they are all objectively "good" at handling (certainly more so than any non-modified E89).
I'm not sure it's accurate to say that a non-msport manual 35i is 40% more reliable than a 35is. I doubt issues with DCT are any more than a once in a car-lifetime event on average, and even if adaptive dampers are every 30k miles on average (being super pessimistic) then that's every 6 years for most Z4 owners - and that is more a maintenance issue than reliability. Where you've given a 35is 5/10 and a 23i 10/10, the reality is that in the grand scheme of things they are probably a 7.5/10 and a 8/10. Neither is a Honda, but neither is likely to break down.
Good idea, but I think the ratings you've given exaggerate the differences between each version and it would be better if ratings were created objectively. And you need a column for colour.... VO = 10/10.
Yes..a gold plated turd is better than a bog stock turd..your point is?Speak for yourself, old bean.
I’ve installed a performance part that allows my 35is to out handle all other E89 models, and many 911s too.
I think he was referring to his undeniable, in his mind that is, driving prowess.Yes..a gold plated turd is better than a bog stock turd..your point is?
It was a stock car comparison…not second guessing how much love someone could/should /maybe perform..
Ah…thank you for enlightening me…I think he was referring to his undeniable, in his mind that is, driving prowess.![]()
Yes, ‘Design Pure Traction’. It’s listed on my car’s spec list. As you say, it has those metal weave pieces as you described. I believe it could be ordered with or without black roof.Was it not called 'pure traction' or something like that? Seem to think it came with a really good looking metallic weave on the metalwork pieces around the gearstick / HVAC control too.
I did think you could spec it, but never actually tried & that ship has long since sailed.
I’ll have you know I’ve the second sharpest brain in America. The first is our Dear Leader’s.I think he was referring to his undeniable, in his mind that is, driving prowess.![]()
You've just put a tune in my head all afternoon with this, 'Brain in the USA' (Bruce Springsteen)I’ll have you know I’ve the second sharpest brain in America. The first is our Dear Leader’s.
