Or is it really necessary to remove bottom coolant hose from the water pump, for accessing vanos unit.?
Yes, on the early M54 engines (2003/4) the lower rad hose has a connector right below the thermostat which fouls the Vanos. You have to unclip the hose (or remove the sensor if that's possible?), and you'll lose about 1/2l of coolant. You can drain the radiator if you want, I just took it as an opportunity to refresh some of my coolant.
question is why not remove the stud then and thread lock it back in when you refit?
Because there is not enough of the stud showing to get two nuts on it to remove it (except the far left one in my case). One of the other guys on here, Midhurstman, lifted the Vanos forward a bit and undid the studs with a molewrench, but I didn't need to do that.
And yes, IF the studs don't stick out too far (we are talking 1 or 2mm of tolerance here), your Vanos will be as "easy" to remove as mine. As per my post, in any case you can wind the studs in a bit more once the unit is out to make refitting easier.
Here http://www.bimmerfest.com/forums/showth ... p?t=394732 somebody used a crowbar to get more room.
Not sure if it's safe to water pump?
That's what I did. I had minimal clearance issues, so with a bit of prying against the water pump shaft I could remove my Vanos quite easily. As long as you don't lever against the pulley (plastic) you'll be fine. The bulkhead has six bolts (four on top and one each side behind the washer bottle and the air filter), these need to come out first. By the way, you will never drop anything into the engine, you are working at the front so the only things you may drop are the nuts onto the engine tray, which is no issue.
