IK. said:Lotus1 said:IK. said:I wouldn't want anything talking to me constantly either! This sounds good, as long as it picks up mobile cameras... They're the worst thing.
Also, how is it powered? And how do you get the updates on it daily?
It's powered via a lead to the cigarette lighter socket but you could hardwire it to make it neater. You have to download the database via a PC to update.
It does have a built in laser detector - see here:
http://www.sciuridae.co.uk/technology/snooper_s2.htm
Steve
Hmm, don't fancy something constantly plugged in. May aswell have my Sat Nav constantly plugged in... Can't battery power it?
As for the laser detector... Surely it's useless? As by the time it's detected the laser, it's caught you anyway!
your best bet will be to hard wire it, its pretty easy run pop out the ash tray, take a screw off underneath, pull out entire assembly which included the buttons for the hood / seats, solder to the lighter port (with car off and disconnect the lighter fuse, id probably also take the negative off the battery to be safe) and run the cable to your desired place, ive managed to feed my tom tom wire under the trim and out by the door and tucked it underneath the rubber trim before coming out by the dash.
