Sorry if this has been asked before but I have no idea what to search for and I need an answer fairly quickly!
When I bought the car about three months ago it had 2 brand new Michelin run flats on the rear and 2 half worn Bridgestone Potenza run flats on the front.
Left work to come home tonight and after a few hundred yards the tyre pressure warning light came on.
Fortunately there was a garage just up the road so popped in to check pressures and, sods law, it was one of the rears which was low on pressure.
Pumped it up and drove home carefully.
I've checked pressures again a couple of hours later and it seems it's losing about 5psi in a couple of hours.
I can't see any obvious reason such as nails, screws etc so I'm not sure what's causing it but hopefully it can be repaired.
My question is though, worse case scenario is it can't be fixed, would it be ok to have 2 non run flats on the rear and 2 run flats on the front.
I believe the cost of 2 normals is about the price of 1 run flat and my aim was to change to non run flat when they needed replacing.
I can't really afford to replace all four tyres at the moment so would have to have just one new run flat for the rear if it's not a good idea to mix run flat and non run flat front and rear.
Hope that all makes sense and I look forward to your advice.
