Slight leak from gearbox?
jamesgarbett
 South Manchester
My manual E85 seems to have a slight leak from gearbox
Indy mechanic suggested it was not worth worrying about
BMW dealer says not covered by warranty as car has done over 60k
Anyone else had this?
auto ? manual ?
07 car & not crazy mileage ? . seems unusual for oil leak on manual gearbox .
is your indy clued up on BMW's ? if not then my first task would be to have it looked over by someone well used to the in's & out's of BM's
I have just had a leak fixed on my gear box. It was the rear output shaft seal. It was causing a leak around the bottom the gear box.
It was uber annoying as the seal was only £20 but the labour of dropping the output shaft and getting to it meant the labour was near £150!!!
