Side repeater problem
Pauly
 Liverpool
My wing side repeater is not working, no bulb issue on the dash and I have changed the bulb just to double check. I have taken the repeater out and the unit seems fine. One side working the other not, I am being daft is there an easy solution? many thanks
Put a meter on the bulb holder and see if you get a reading. If not then sorry but just start working back along the loom and connetions.
Cheers CJ will do tomorrow, think this issue if it's a lume problem will be covered under warranty? still got till May 2011 left!
Finally got round to putting a bulb metre on the holder and nothing! Popped into my Stealer's today who informed me this should be covered under my warranty, so will get it into them and they can tackle this issue rather than me out in the cold!
Just try pressing side repeater into a hole in car wings then held in place by clips that are part of the side repeater.Then try connecting to 2 wires,running up the inside of the cars wing. Just give a trial no harm doing so.
