Isn't a convertible a 'tranny' - a roadster that sometimes identifies as a coupe?I’m not sure you can say “tranny” nowadays. Someone might have a meltdown!
Or tranny and mount in the same sentenceI’m not sure you can say “tranny” nowadays. Someone might have a meltdown!
Have a look at the CoolerWorx short shifterFor those that have had it done keen to hear what worked. I am trying to reduce the throw length so the throw is shorter and more rifle bolt like compared to factory.
I also need to get transmission oil changed. Car has done bout 43k miles but not a big fan of the gear shift.
The spring in mine has held up perfectly well for a number of years on a shelf in my garage…!Coolerworx do a nice shifter - beware they do require some modification of the plastic trim on the transmission tunnel to fit, and I believe their centering spring is a little weak...
