So just had inspection two done at main dealer, got a good rate as work for another garage owned by the same franchise so get a good rate, however Tbh I had a awful experience with them which shocked me given working in the same group would expect us to look after one and another kind of attitude,
Anyway I had requested the report on the valve clearance check - it didn’t come with the invoice so I asked about it and got send a new invoice break down with the following written in it
‘ Inlet all cylinders within tolerance except for Cylinder 2 inlet which needed 1.84mm added and adjustment. Tolorance is between 0.18 and 0.23mm. Outlet within tolorance between 0.28 and 0.33 except for Cylinder 5 needed 2.12mm added and adjusted’
Never had a report so does this sound right as I was expecting something more elaborate tbh
