Sharp 'clicking' metallic noise in front of car related to bumps and when car is warm?
Hi I wonder if anyone can help identify the source of this 'clicking' metallic noise. I've had two mechanics in the car, one from a local BMW garage, another from a local indie garage listen and it only appeared with the Indie one. I had the Indie change the two front lower control arm bushes attaching to the bulkhead which I thought was the sound he was hearing, but apparently this cured the bit of back and forth play of the front wheels only. It can present / be heard quickly but it can also take a little while to hear, I thought it was first of all on the left hand side when I went over one of the many dastardly road humps we have in the destroy a car environment I live in. It was also mentioned it could be related to the exhaust manifold moving and needing some tightening up or nuts replacing? I did check the engine braces were all tight too. Grateful for any thoughts / help. I haven't managed to get the car on a ramp yet and not sure I would immediately sees anything either with the bottom trays on place?
Have they checked top mounts? Squeaks and cracking noises can come from failing top mounts. My rear was doing it had them replaced and all good.
Metallic clicking - brake backing plate touching the disk? Is it worse on tight corners?
