Ewazix said:Smartbear said:Ewazix said:The ECU has a stock map for fuelling, if you have rough running and disconnect a suspect MAFF and it runs fine, that suggests that input signals from the knackered MAFF are the likely cause ........... or so I have read on here previously![]()
I know this, that’s why i asked the op how it ran with the suspect maf disconnected :wink:
Ahhh "how (well) does it run disconnected", rather than "how does it run when disconnected" (as in how is it able to)![]()
That’s the one
