Service cost & Intervals
earthdweller said:
I think condition based servicing has caused all sorts of confusion
It's in the small print saying that cars should be serviced every two years if they haven't hit the mileage to trigger the next service
But even BMW dealers don't follow the "small print"
There was a coupe on sale here recently for top money, albeit it had only done 20k in 11 years .. but it had had two oil changes in that time and was being sold as full BMW service history
Following the "small print" it should have had at lest 5 services and an Insp 2 which should be done at 8 years regardless of miles ..
But conversely you can be too anal about it
Mine fior example has a full BMW service history but had serviced every 2 1/2 to 3 years so not quite to the small print ... but as it's got older and gone to enthusiast owners the services and maintenance has got much more frequent
I walked away from one advertised as full history .. and it did apart from the 5 years it was laid up .. then a guy bought it and just used it for a year without doing anything to it and couldn't see anything wrong with that !
My view is that as a car gets older it will fall into one of two catagories
1. Cheapskate owner
2. Enthusiasts owner .. and I'd expect it to move yo annual servicing at the least as it gets older
But that is just my view
Sorry, not quite correct. Oil and brake service as a minimum every two years. The inspection services are mileage based so technically an inspection one would be due around 26k.
1. Cheapskate owner
I'm sure that's what I said !
Service every two years .. but the Insp 2 should be done at 8 years regardless of mileage
Which kind of makes my point .. CBS causes confusion !
No, service 2 doesn't have to be done at 8 years, its mileage (linked to fuel used, for completeness ) related so @ 2k per year would be roughly 13 years between inspection services. TBH though I wouldn't let it go that long.
No, it's fuel used linked to mileage lol. :rofl:
Indeed. Mine was getting pretty tappety prior to Insp2.
Well after recent thread :wink:
Hi guys. I know this has been done to death, and I haven’t posted anything interesting on here in a year (s) :tumbleweed: but ...
I’m confused. Servicing dept says she’s due ins 2, which is what I thought. But having read loads on here, I’m wondering if it is an oil change instead and perhaps mine has been over service before and in my care.
I’ve done 2k since the oil service last year, 6k since insp 1 2 years ago.
Soooo ... insp 2 plus brake fluid, or oil change plus brake fluid. :roll:
Unless you’re doing interim oil changes in addition to the BMW schedule then you aren’t due a service until either the service indicator is displayed or until October 2018. Unless you’ve had the car constantly on a race track in the last year then the service indicator isn’t going to show after only 2000 miles since your last oil service.
As far as I'm aware
It's inps1 oil oil inspec2 oil oil inpsc1 and so on
As that's how mine is and I do oil, diff and box myself as well in between
Just had my inpsc 1 plus plugs and clearances all done and all good
£700 all in from Bmw
In short they are charging you for insps it doesn't need
You only need an oil service plus brake fluid. Oil and brake needs to be done every 2 years as a minimum to meet service schedule. Inspection 1 and 2 are mileage/condition based.
I only do 2k per year on average so will have additional oil services otherwise I’ll be having inspection services every 8k. An additional oil service would take me to approx 12k which is still half of what a inspection service would be done it based in mileage/condition only.
The 56k oil change was really "interim" Tom , nice to have the stamp but sometimes best left out of the book to avoid this confusion ( though made a note of )
Then around 64k oil service with stamp then another interim around 70k not stamped followed by Ins2 around 76k .
Thanks a lot DGM / D4dawg / srhutch / Mr W! I will try make my next post more interesting :rofl:
Technically the inspection 1 was done a year early. Be interesting to know why that was. Maybe part of the purchase agreement. Hadn't looked at the pics before posting this morning I have to confess.
D4dawg said:
As far as I'm aware
nearly.... according to the schedule , insp1, oil, insp2, oil and so on.... not oil oil..... then an insp
Glad I found this thread as I'm in the same predicament, the dash display says I have 8k miles to Insp 1, however I have only covered 6k miles since my inspection 3.5 years ago. I believe when I had an oil service at the main dealer nearly 2 years ago (time not distance) they reset the service counter which advanced it on to Inspection 1 from oil service.
Basically if the car is on short mileage and getting time based oil and brake fluid changes every two years it would seem that they should not reset the counter otherwise you wont know when the next inspection is truly due.
So am i right in thinking that I just need another oil and brake fluid change and to run the counter down more before the next proper inspection with valve adjustment?
To further complicate I change the oil and filter myself every year with a vacuum pump, this is purely to get another stamp in the book for the vehicles history, shall get rear brakes renewed at the same time.
Adam
The time based oil changes should definitely not have the service counter reset, but should still be recorded in the service book.
This, but you can work out pretty well when it will be due. Roughly 26k between Inspection services.
