meitme said:
So pretensioners aren't a worry? I only mention it as the seller said to be aware of pretensioners in his (stock) listing blurb. As far as I can tell I shouldn't be touching the seat belts other than to unhook them though.
They shouldn’t be, provided you’re swapping E85/E86 seats for other E85/E86 seats (so M versus ”comfort”, for instance). You’ll need to unhook them from the guide at the top and also remove them from the rail mount below. Easy enough, and simply reverse for installation.
As for the easiest way in a coupe (to me at least). Remove the bolts, undo the belt top and bottom, tilt forward slightly and rotate towards the centre console, tilting the seatback to the horizontal position over the console. Bearhug at the connection between base and back, and slowly reverse our. Be mindful of the metal rails over the kickplates and side skirts, and rotate away from the door slightly as you exit to prevent the frame from touching the doorpanel. Tip: lower your windows to give yourself more space and less risk of knocking the glass. With a bit of practice, you can remove the seats in 5-10 minutes (waiting time for the airbags not included).
Good luck
