seat belt warning
bazzab
Evening all,
I've currently just purchased the bm technic lead and software to rest my airbag light after ive fitted a passenger occupancy bypass
,which worked brilliantly.Only issue I have is now the seat belt buzzer starts obviously as it thinks theres some one sat in the passenger seat and they've not fastened their seatbelt. :rofl:
My question is this;does anyone know how to disable this in the bm technic software(I think its sss progman).
If so could you direct me to the correct menu/function?
On the positive side ive managed to change some settings(auto lock when moving,visual alarm when locking/unlocking and a couple of other features),all in all a great tool(not me,the software :lol: ).
Thanks in advance daz
Yes, go into SSS and its really obvious in one of the menus, possibly retro fit, but it's easy to check them all, it's definitely there
cheers liam-o,anyone else know for defo?
Ill check tomorrow as battery was getting low and swmbo was whining as I was spending to much time messing with car.
I dunno whats her prob,thought i'd got my priorities right :D
cheers daz
It's i retro section but you must install change.iso files found on net, to allow this menu to work.
Basically in the top right of SSS it tells you the voltage, as its a copy program this can only be altered by installing some software and manually You can adjust the valve to over 14. If your software state the voltage to be 14 or over then you will be ok.
