B21 said:RedUn said:That looks ideal! I've got the same height restriction to I'll be going for a metre too! I can't seem to find one for much less than 2k at the minute though which is slightly annoying!
https://www.ebay.co.uk/itm/324341926133?hash=item4b844908f5:g:UkEAAOSwJ-ldCqfU
stevespg said:B21 said:RedUn said:That looks ideal! I've got the same height restriction to I'll be going for a metre too! I can't seem to find one for much less than 2k at the minute though which is slightly annoying!
These have bars that cross under the car, making access harder. I used one once. Was impossible to work on exhaust, gearbox etc.
stevespg said:This is the kind of thing I have, it has compressed air safety locks which mine doesn’t, which would be ideal but I didn’t have a compressor at the time I bought mine.
(I always put a set of axle stands under the scissor section of the lift which would prevent it lowering in the event of a catastrophic fail).
https://www.ebay.co.uk/itm/AB-MR3000-3-ton-Scissor-lift-Car-Ramp-3-YEAR-WARRANTY-1390-VAT-/153445526164?mkcid=16&mkevt=1&_trksid=p2349624.m2548.l6249&mkrid=710-127635-2958-0
There are a few suppliers, mostly of Chinese origin (what isn’t these days!!), but Automec and others sell alternates.
stevespg said:Yep. Fits easy.
The tam is pretty low and fits over .. close but ok.
The 40mm thick blocks of wood I leave under the ramp slopes just so I can slip the hockey pucks under the chassis easily, (without the blocks I have to lift the front arches 5 mm shove them under a bit blind), and because I don’t really like slipping the clutch when the car’s stone cold on the tam every time I use it just to reverse over the ramps to exit the garage. The clutch is a bit of a “switch” when cold and you’re holding revs to keep the engine on idle for the first minute or two.
The z is less fussy and no issues.
