On the E85, that #2 button is to reset the tyre pressure reader to the current pressure. If the old noggin remembers correctly, the recommended cold tyre pressures were 36 front, 38 rear. Optimally, you set those cold pressures, hold the button down until a coloured symbol pops up in the cluster, and continue to hold down until the colour changes. Then release the button, drive, in a few minutes the symbol turns off, and Bob's your uncle. If one or more tyre pressure drops below the pre-programmed optimum level, the cluster symbol turns on with a warning beep.
The DSC button has two levels. One push turns 'some stuff' off, a long hold turns everything off. The E85 (at least mine) doesn't have a computerised diff, so you don't miss on anything by turning everything off. The E89 35is has a computerised diff, and presumably you don't want everything off. I reckon if it had a proper LSD, then it'd make sense to turn everything off.
