SatNav display - blank / not powering up
tertius
Hi,
Anyone had an issue with the SatNav/audio display not actually turning on? I've done a search and most issues seem to be with the display not lifting up, however, in my case the display lifts up fine but is completely blank.
Is there a fuse or anything I should check?
Thanks in advance.
have you tried the Chinese reset?
Disconnected the battery and re-connect to reset the system. It's always worth a try.
Give it a few minutes before re-connecting
Good luck
Mine has started playing up - has now gone blank. Lifting fine, sometimes comes on but then has lines across it and fades to black? Did you find any further information?
Mine did this once in my Coupe, just disconnected the battery for 10 mins and it never did it again.
Not sure what caused it though but when it crashed it looked like an old Speccy game loading up.
