Update time!
I dropped the exhaust to get more clearance and work out a better flowing system. As you can see in the first picture the S65 headers bolt up to the E46 exhaust system so all that is needed at a basic level is just rerouting and one can maintain the same flanges. Makes for an easier job.
Getrag DCT trans next to the S65
Time to pull this sucker out...
Let's compare...
It does appear the DCT is a tad longer. Shouldn't be a problem.
The next challenge to work out is figuring out how to do all my hosing and tubing for coolant, AC, powersteering etc. I've come up with what I believe is a really simple and great idea. Retain the stock fittings but weld on AN connectors to run custom hosing. The pictures should explain this further. I'll have these done before next week is out.
Material removed
All the connectors
I will have to remove the heater core to take by my welder to have the connectors fabbed up
Inventory time
Everything labeled
Getting the DCT trans into it's seating position
Getting a spare S65 block into position to see how it lines up with the trans and subframe and rack
Obviously nothing is perfect fitment here but we are only going for ballpark estimations right now. I still need to look at my headers before I build engine mounts
Everything is high enough to not cause any safety issues
Here is how the trans mostly fits. You can also see why I have to relocate the heat exchanger
I'm looking at getting the E9X condenser and deleting my drier bottle from the Z4. The E9X condenser has a built in drier so there is no need for the bottle which would free up some room in engine bay.
Let's compare...
Material removed
All the connectors
Inventory time
Everything labeled
