s54 rod vs main bearings
I wasn't going to respond to this, as there seems to be one of these every year or so.. but
Its not the amount of track days, or how high rpm you run, bearing shells cop it when the engine/oil isn't warmed up to spec and then given a hard time. no idea if swapping out oils early makes a difference, but i swap mine after every 3 or 4 depending on how long between track days. (thats probably too much as most of the guys at my track do every 5)
Best insurance you can do is just warm up your car properly before giving it the puhjesus, and as importantly, a proper cool down.
Shells should last up to 200k, but probably should be looked at around 100, as it is a consumable.
:thumbsup:
R60BBA said:
Wouldn’t bother doing main bearings unless the engine is super high mileage, at which point you might as well take it to Redish and get a full rebuild for £4,000 all in.
https://www.redish-motorsport.com/BMWE46M3S54EngineRebuildRefresh.html
I don’t think that’s bad money tbh :driving:
:thumbsup:
The cold starts and also how oft you replace the motor oil are playing a bigger role than high rpm in the life of the rod bearings.
Those rod bearings are on the s54 extremely thin (2 mm thinner than on the S50).
And when you don't know how the car has been driven in the past, it's a good investment to let them replaced between 80,000 and 100,000 km.
I've had mine since 2008 and 9,300 miles, so I know how it's been maintained. During the AUC/Insured Warranty period (up to 100,000 miles) it was serviced to schedule by BMW plus interim services myself, with an oil change about twice a quarter (I was doing 2,000 miles a month).
I've always believed in a proper warm up, and something that was instilled in me during my e34 M5 ownership, where valve clearances were every 10,000 miles.
It wasn't unexpected, and an overhaul was planned as a winter project, but it just happened on the last trip to the Ring that year (just after my mate drove it).
When we got it back, we thought it was just going to be a simple job as we'd stopped the engine the moment we heard the slight unevenness after a lunch break (it was fine when we were driving around the area, and before we stopped) - we only noticed it when I restarted after filling up. We took the filter out and it was covered in metal, we then took the filter apart and the inside was almost as bad. Took the cam cover off and it was like a glitter party in there.
So., we decided at a minimum it would be a top & bottom strip down anyway to see what everything was like, but as we found metal particles EVERYWHERE we decided if we did do a rebuild we'd do some upgrades too.
But them my mechanic got seriously ill, so everything went on pause (which happened to be longer than either of us hoped or wished for), and we decided that we'd see if we could get a good engine (a Z4M S54, not a e46 S54) with all the ancillaries so we had spares, we'd go for that, as a swap would be much simpler for him than spending time stripping & upgrading - and less costly overall.
where.is.lee said:
guess it comes down to luck of the draw, how many track days prior to it going bang?
30+ in 10 years (Oulton Park, Cadwell, Ring), but multiple oil services every year, plus basically an Inspection II every year, and fully warmed up before unleashing the right foot.
BTW, there was no great shock when it happened, and the refresh had been budgeted for. We've always had European breakdown recovery (ADAC Plus originally, until they refused to recover my broken down M5 to a local garage due to it being a Bank Holiday weekend and everything being shut) for the inevitable repatriation we'd need if we had a breakdown...the only sour note was having to pay £1500 to get it home after the breakdown company refused to repatriate the car AFTER WE'D LEFT IT WITH THEM IN GERMANY and come home in a hire car ourselves. Took 6 months and the Ombudsman, but we got refunded, and the breakdown company got a slap.
where.is.lee said:
wow, that is a thoroughly maintained s54 and yet still shat itself, guess it's one of things that need to be done.
It could have been much worse, and shat itself at 140mph on the track :P
It is known as a bit of a "Trigger's Broom" car now - as almost everything other than the roof, bonnet & shell have been repaired/replaced (including engine & mounts, 2 diffs, suspension & bushes, brakes, clutch & flywheel, wheels, exhaust, seats, cooling system, wheel bearings, etc.). It's almost new :thumbsup:
The plan for spending £2k over the winter would only have been a small budget increase over the cost of running it for 25,000 miles a year anyway...and spread over the 10 years I'd had it at the time is only £200/year (man maths).
It was never meant to be a stripped out track car, it was bought to replicate the myriad duties of the e34 M5 in a newer, more sprightly car (maybe lost a little luggage space).
Anyone who's been on a forum drive with me, will know I'm not one for holding back on the loud pedal - no matter if I'm in a Z4M or a diesel Alfa 147 :P
mmm-five said:
Status said:
But if it ain’t broke then it ain’t broke is it so leave it until it needs sorting
Mine wasn’t broke, until it broke, on the way from the Ring (luckily not on the track) ...which meant a potential £5000 rebuild (went for a low mileage replacement engine instead) rather than £1000-ish preventative maintenance...plus a fight with the recovery company about repatriation.
Mine was at 160,000-ish miles.
Main bearings, really?
No. rod bearing shells :thumbsup:
But other preventative maintenance (or upgrade) considerations at that mileage were in my mind when the discussion about rebuild/upgrade vs low mileage engine came up (ended up with a 43,000 mile one).
I’d probably do wot Mr Tidy does but I do about 5 thousand miles tops a year I don’t thrash the nuts off it and the fluids get changed every july,They say the s54 is a good engine but as far as I can see they ain’t that good if you have to do all that to em once they’ve clocked up a couple of miles,mines only done about 53 k but makes me think about selling it when I hear about all this stuff and get something that’s a bit more bulletproof ,Even my scoobies can be prone to blowing engines and gaskets so I’m a bit careful with them
:thumbsup:
Vanne, I don't think it's that simple. If you read my rod bearing change thread over on Zpost, warming the car up doesn't give you much more insurance...but I still do it just for the sake of mechanical sympathy.
Too many variables to say one thing or even two things can save the bearings, a few things can shorten the time expectancy of the rod bearings
Too much load when cold, wrong oil, poor servicing, the list goes on
When BMW designed the S54 they made the rod bearings narrower and the bore wider, think of it as a drawing pin.
They also designed a poor diff for the Z4M as the left hand side output shaft is not nearly long enough have a look at one in bits and you will see what I mean
The cup holders where designed by an engineer that has now only just passed out of Uni as he designed them when in pre school.
The location of the roof motor was desided when there was a beer festival on with free beer and only 15 mins to come up with an answer as to where it was to go.
Other than that good cars
:thumbsup:
My question had a little variation, not when to replace rod bearings, but rod vs main.
Was wondering why mains are never mentioned, didn't knew they were under lesser stress.
PDJ said:
drawing pin
:D
Agree on the cup holder, roof don't know (have coupe), but bearings were intentional to reduce friction and increase responsiveness (I heard) and that shaft should be ok right, I mean, never heard those failing, they either reach their mounting spots or not/barely and break.
160,000 miles including track use on original bearings is good usage.
It's unfortunate that yours spun just before you were about to commit to the service.
Track guys on other forums change theirs every 25,000 miles, and I believe race teams change them after every season.
Out of interest, what oil did you run?
It was always one of those things on the schedule (but not until it was past 100,000 miles), but other things kept taking priority.
It was run on OE Castrol 10w60...and only ever Shell V-Power, Tesco Momentum or Aral Ultimate 102 at the Ring (or Super E5 for the drive home).
The 115bhp 146 JTD beast got the cheapest diesel I could find whenever it needed it (which was usually less than £1/litre in Germany). Even that got 5,000 mile oil changes.
