ga41 said:
Keep in mind though that in cases of high-mileage engines there might be a need to fit oversized rod bearings because the crank might be worn. We had to do that to my rebuilt engine. My mechanic sourced all the required parts.
You can only fit oversized bearings if you grind the crank (for example if its worn/damaged).
Shells come in 2 sizes, oversize is +.25mm.
Radial rodbearing play should be plastigauged between 0,030mm and 0,070mm and maybe use a micrometer to check roundness.
FD3S said:
Also some friends say that since that is a complicated job you need it done by an expert. Is there any way that you can verify that you mechanic is suitable for this job? Any other advice for someone that will change them?
In theory any good mechanic should be able to do this. But usually indies who work on old cars wont have any plastigage or micrometers lying around. But all specs are in the TIS manual, so its doable.....if you have a good mechanic.
Grinding a crankshaft obvously is work for a specialized machine shop, but I doubt that has to be done to your engine (measuring the bearing play should point that out).
