Z Z4M-2006 Elite High Peak,Derbyshire. Feb 14, 2016 #1 S54 cam cover gasket,plug hole gaskets and bolt hole "O" rings.. OEM from BMW Stockport Redline friction modifier for the diff... Opie oils Cost approx £110 for the pair for the bundle.. £60 inc P+P....
S Scaramanga Member Feb 14, 2016 #2 Sorry for my ignorance but is this useful as preventative maintenance ?
Z Z4M-2006 Elite High Peak,Derbyshire. Feb 14, 2016 #3 The friction modifier is put in the LSD when oil is changed on Insp2.... Helps the plates stop chattering or grabbing.... The Gaskets should be changed when the valve clearances are checked..
S Scaramanga Member Feb 14, 2016 #4 Ok. May be interested, just need to see if the car I've found is worth buying.
