Rust on front of engine bay area
shuey
Hey all
So I’m looking to buy z4c at mo and was going to view one - but is about two and half’s drive away from me.
The owner has been quite honest and sent me picture of rust as shown on pictures - is this rust on the chassis or a part that looks replaceable?
Does it look like an expensive fix from the picture shown?
If it’s not the chassis then what’s that section called so I can find out cost?
Also he’s only had car for a 5 months which is a bit of a concern
Hi, It's not chassis. It looks like the metal strip that helps hold the front bumper in place and should come off when you remove the clips/screws. Then you can sand it down and respray it yourself.
See here https://www.youtube.com/watch?v=OP4ZBkUcxxs
My old 2.5 had a little bit towards passenger side, the slam bar is easily removed for treating and painting!
There also some available on eBay for £30-35 if you want a simpler life! :thumbsup:
That metal strip sits on top of the bumper. Undo the 7 torx bolts and the metal strip can be removed.
I resprayed mine as it had a bit of rust on it. Looks fine now.
