I had some FK452's fitted to today, and after about 7/8 miles the tyre warning light came on, I managed to reset it straight after. Did this happen to anyone else after they ditched the RF's? Any possible explanations as to why?
Did you remember to reset the monitor just after the new tires went on? If not, you would get the warning as there had been a change from before. Also, did you check that all the tires are properly inflated?
No, I never reset it. Now that I have reset it after it came on, will that sort it? I am going to check the pressures now, have been working on the assumption that they are ok, but will make sure.
yup you need to reset the RF tire monitor everytime you change pressure, change tires, if one of your tires slip, roller dyno'd. but to be sure check all four new tires for their pressure
