Artful-Bodger said:
Not sure where your seeing a ball joint in the rear M suspension? which model do you refer to?
33326775551
It's a replacement for the upper bush?, that's good if it's an actual balljoint with dust protection, will order one to have a look for my rebuild
Here is good advice on the fitment of uprated bushes for the M onto the Z4 - http://www.vorshlag.com/product_info.php?cPath=1_4_26&products_id=515, you may note they mention the issues with using polyurethane, this does merit some further investigation, there is a fair bit of information on the subject.
They are trying to sell their own product....... so they write this piece with a commercial interest.
Just as in that other discussion someone also blindly believed what commercial websites had to say that would fit right into their offered product line....
They also say for instance "Polyurethane can and will cause suspension bind." which is 100% NOT true if you dont go over shore95A. That shows how badly that piece is written and how much they want to sell their own product. Only a fool falls for that. In that other topic I posted a video to prove that (as my hands on experience wasnt believed...)
Well on this I would have to disagree with you, the two interacting arcs of the rear suspension require deflection in the bush, poly is not an ideal material for this application, BMW use rubber for a good reason , especially as poly is so cheap, can you think of any mainstream manufacturers who use polyurethane bushes?
I have fitted poly bushes on a couple of cars for competition work with road tyres and the results are the same, if your replacing worn rubber with new poly you will see an improvement,
And I have actually fitted it on a z4, and my previous bushings werent worn.
And also then its an improvement. There was no such thing as slack or seizing up as you speculated. (as seen in that video I made)
I referred to binding, not seizing, as I mentioned above it's a geometry issue because the pivot points are not on the same axis, again BMW use rubber for a sound reason.
out they came and in went the Powerflex, after much fiddling to get them working
I swapped all my bushings on the rear axle in little over 3 hours once I had the rear axle out. Yes, that is all 19! bushings in 3 hours (well 15 bushings and 4 ball joints to be exact). Getting the poly bushings in is much much easier and faster than oem rubber ones.
So I dont know where the much fiddling part has to come in, maybe its a personal thing. I had none of that. It was a matter of putting them in, lubricating and go. simple as that and they have been there for years now, on a rear axle that gets about 66% more power than stock.
So everything you seem to have experienced on other cars hasnt been happening on my install on the z4 it seems.
The fiddling I refer to was the requirement to skim bushes to move freely once installed at correct torque, I have no idea of the requirements you apply when building suspensions, but over 20 years in Sprints and Hillclimbs and building a variety of modified road cars to full race Sports Libra spaceframes has given me considerable experience with what I need to achieve, at present I am not inclined to use polyurethane due to my experiences with it
It's up to the individual but I would not use poly bushes on a road car, especially if there are uprated hard rubber bushes available as there seems to be for the M models.
I'm sorry to say so but this informantion is also incorrect. The z4m uses exactly the same bushings as the normal z4 does. So rtabs and both inner lateral arm bushings are EXACTLY the same. If you think otherwise...you're misinformed. The only difference -as I already wrote- is that it uses the upper outer lateral ball joint also on the lower outer lateral joint. And thats an easy upgrade. There are also poly bushings for this point but you can just as well fit that balljoint. I believe its even cheaper too if you dont get it at the stealers.
Meyle HD has a bushing that is supposed to last longer, its not made to be significantly stiffer. HD stands for high durability.
So that will still have lateral movement (without limiters that is) and longitudal movement (limiter rings dont do anything about that)[/quo
Well it seems the Z4M uses a more compressed bush, that is the information I have at present and until I can confirm this I will simply say YOU may be wrong, whilst the rubber is the same hardness the installed compression is apparently greater, I am taking this at face value until I get a bush for testing, I will be changing all my bushes this winter but not until I have certainty over what parts are available, as for the Meyle if they have a service life superior to the stock item I will also be looking at those, they are quite cheap so there's no harm buying a couple and taking a look
