Better with the tool and I needed it to get the poly in
Ducklakeview said:Ok, all done now with Meyle HD bushes and limiters. Was surprised how much corrosion was present on the bolt heads and bush carriers! This added 30 mins per side as I had them on the bench grinder wire wheel, followed up with a couple of coats of black metal protecting paint dried with the heat gun. Used my trusty kitchen fitting level clamped to the bush housing and lined up with the wheel centre to set the correct position as per TIS. Think mine was on original bushes as they marked BMW, and car only on 55k.
I clamped the new bushes in the vice and slipped a couple of jubilee clips on them to make them easier to fit, but then noticed that the OUTSIDE edges of the trailing arms have a decent chamfer on them so probably wouldn't have needed the clips. Biggest PITA was fitting the carriers back in with the limiters in them as they are a snug fit. I just made sure the edges of the limiters were past the edges of the steel centre of the bush, meaning that they were actually angled inwards in the carrier, and tapped it home with a dead hammer, which slid the limiters into place. There is virtually no twisting of the carrier possible now with the limiters in, I tried the old bushes before disassembly and could easily twist the carrier by hand.
Typically it's now raining so can't go hooning, I mean testing..
Mike
Artful-Bodger said:Ducklakeview said:Ok, all done now with Meyle HD bushes and limiters. Was surprised how much corrosion was present on the bolt heads and bush carriers! This added 30 mins per side as I had them on the bench grinder wire wheel, followed up with a couple of coats of black metal protecting paint dried with the heat gun. Used my trusty kitchen fitting level clamped to the bush housing and lined up with the wheel centre to set the correct position as per TIS. Think mine was on original bushes as they marked BMW, and car only on 55k.
Mike
I have a set of 4 of the Upper rear balljoints here ready for fitting, they also fit the lower bush location so I have 4 to eliminate the lower bush from the upright (hub carrier), that's 33% of the flexible bushing removed from the rear in one simple swap.
I have a set of Meyle HD RTAB's on order and will compare the rubber hardness with the standard BMW one I have, I note on the bush there are two tabs on either side, these seem to be designed to either do a similar job to the limiters or to eliminate any clonks as the bush hits the housing in roll, did you check the lateral rotation of the bush before fitting the limiters?
I have a concern that there has to be sufficient movement when the suspension arm moves up and down in it's arc, as it does the joint has to twist so it needs space to rotate as it does so, the design of the housing has the two "domes" centralising the bush but leaving space for it to twist, so would the limiters be "pinched" by the bush or arm during that movement, if it does this will cause torsional loads to be applied to the arm and housing?
I can't find any info on this or if anyone has checked the required movement, so short of dropping my cars rear suspension out (not planned until October) I'm at a loss to be able to confirm the mechanical action of this?
Artful-Bodger said:It looks a tight fit, problem is with the carrier bolted up into is location it's really difficult to check the movement of this part, only way I can see of doing it is to use longer bolts and spacers to lower the housing down so it's visible whilst measuring the gaps, I'm taking the car off the road in October and I will test this movement with the old soft bushes in place so it's easier to move them.
Really need to know what's going on in this location as you can see it's been designed with the lateral rotation in mind.
Ewazix said:As soon as lateral cornering loads are introduced in to the equation with road surface and camber changes you will get (and need), movement the trick for the designer is harnessing movements to affect geometries in a useful way, so every bush, spring and damper is designed to work literally in 'harmony'. In the case of many multi-link set-ups a slight 'rear steer' is engineered in to affect understeer/oversteer traits. This is why I'm suspicious of 'upgrading' single components (e.g. with solids or poly), you may improve one characteristic but adversely affect another, sometimes you won't realise until the machine is on the edge.
GuidoK said:Ewazix said:As soon as lateral cornering loads are introduced in to the equation with road surface and camber changes you will get (and need), movement the trick for the designer is harnessing movements to affect geometries in a useful way, so every bush, spring and damper is designed to work literally in 'harmony'. In the case of many multi-link set-ups a slight 'rear steer' is engineered in to affect understeer/oversteer traits. This is why I'm suspicious of 'upgrading' single components (e.g. with solids or poly), you may improve one characteristic but adversely affect another, sometimes you won't realise until the machine is on the edge.
If that really is your greatest fear, one should definately stay away from limiter rings as there lies the biggest limitation/restriction in compliency movement within the suspension of the rear axle, not within the fact to use polyurethane or not.
In fact, most limiter rings are even harder than most polyurethane bushings, so the latter one would be a great compromise within your reasoning :wink: :roll:
But all of this is specualtive content. It contains no recorded or proven facts. We know how bmw built the rear axle but what it was ment or prognosed to do is all pure speculation. In that light all aftermarket hop up parts arguments can be swept off the table, and the stock car will probably be the fastest car. But we all know that isnt the case.
And see there you go wrong. polyurethane isn't a 'plastic bush' :roll:Artful-Bodger said:, do you really think just stuffing a plastic bush in there is even remotely as well developed?
I have an engineering background. do you?Most people who modify cars have little clue as to what they are really doing as they have no engineering background,
the Z4's interior rattles and squeaks to begin with on stock suspension. So from factory its apparantly an unacceptable road car?and rattles and squeaks to start from interior trims etc, that's totally unacceptable on a road car.
This is about rtab's. I'm sure that if you buy a coiloverset at intrax (I think the only company that sells a rear coilover for the z4), they can advise you how to brace and reinforce the rear shock towers to take the load. They are a very knowledgable company with far more experience in engineering than you or I have. They did the suspension for michael shumachers world titles for example.The we have the guys who don't put any thought into what their mods are doing to the structure of the car, take coilovers on the back of a Z4, the standard spring perch feeds the loads into the chassis rails and distributes them over a wide area, this is a critical design which the maufacturers spend huge amounts of time and effort on, coilovers apply all the loads into the inner wing and turret, a component not designed to accept these kinds of loads, on a race car you would tie in the roll cage to the mounts and use these to spread the load across the vehicle, on a road car your relying on sheet steel with no support, not a good idea!
Yes I did consider.How about lowering your car, did you ever consider the suspension geometry is now working in a different range, resulting in the roll centers being displaced, the roll axis being changed, camber gradient being put out of control parameters?
No its not, You think that all people here are somehow very stupid, dont do their homework and just slab on some bits.Modifying a car is far more complex than you think!
