pvr said:uh - yes, as there are always costs involved for each improvement. That is why third party companies can make a living as not all components are optimal in the car.
Mr Whippy said:I just think we need to be cautious when buying things on the claims made by the seller themselves.
A proper independent test would prove the benefit, but none have been done. Until one is, it's basically an expensive piece of plastic to make you feel good, a snake oil product basically.
You may as well buy those £5 (but actually cost 10p) eBay resistors for what it is worth. At least they REALLY do alter something, albeit not the best way
Dave
wooter said:Don't forget that the M3 CSL was also an improvement of the standard M3. Reprogramming, airbox, air filter and air scoop were part of that package to squeeze out 27 extra hp.
I'm not claiming that the RPI scoop will generate you 1/4rd of that performance gain, but if you get a Gruppe M airbox, special air filter, ES software and the RPI air scoop, why would it not stand to reason that performance gains would be made?
Mr Whippy said:wooter said:Don't forget that the M3 CSL was also an improvement of the standard M3. Reprogramming, airbox, air filter and air scoop were part of that package to squeeze out 27 extra hp.
Because there is no scientific proof.
If we all just start believing wild claims made without evidence, then we buy a load of crap like this little 12v fan 'superchargers' that you stick on your intake to add 50bhp and the like. Very simple tests prove these are nonsense, so we dismiss them quickly, but these scoops and intakes are so subtle that very specific testing needs to be done, and ideally using different methods. Ie, a manometer testing session through the intake system, acceleration tests at speed averaged, @ wheels same day dyno testing etc.
Sounds excessive, but none of those things, like airboxes, special air filters, new ECU software, and air scoops, are cheap items, and if the manufacturer didn't do those above tests for them, then they are just as much kidding themselsves as they are their customers. So they either have the proof and realise it's poor so won't release it, or they don't have it and so have no idea how good it really is.
Either way, that means ideally the customer should prove the worth and benefit of these things if they are buying them for the power gains.
Yes, I'd buy an exhaust more on sound and build quality if I wanted a new sound, and not for power gains really. But these scoops offer nothing except their promise of a gain in power, so lets see some real proof
I'd love to see them do something positive I really would, but I'd want proof!
Dave
daz05 said:wooter said:Don't forget that the M3 CSL was also an improvement of the standard M3. Reprogramming, airbox, air filter and air scoop were part of that package to squeeze out 27 extra hp.
The CSL gains its power from more than just the airbox modifications. Camshafts are also revised. Gains are made from the programming from all of these mods put together. An air scoop will give you nothing.
ellerpe said:Lots of good discussion, which I believe to be a good thing.
One item I noticed missing in this thread was the affect of sound ordances the manufacturers have to meet to certify their vehicles. While it is true, most manufacturers are not going to let a little $1 part keep then from making more horsepower, the fact of NOT meeting sound regulations may pursuade them to do so.
If making an additional 5 hp doesn't allow them to pass the sound test and sell thousands of vehicles, that 5 hp will be sacrificed. So I disagree with the outright discussion that if the manufactures could make the hp, if they could. I don't believe that to be true.
They will make it IF they can pass all the regulations. Period.
Aftermarket can get by with a little fudging, that's where some of the small claims are made, in BMW cases, when they can exheed some of the tight regulations. I believe everyone here who has ever modified a vehicle, whether car or motorcycle with a alternative air filter, will admit the noise level goes up. Hp may go up slightly too, maybe. Add the same to the exhaust and now a vehicle can't pass regulations. Manufaturer backs off, makes 330 hp instead of 339 hp, but can now sell tens of thousands of cars.
A no brainer to me.
Tell us what you think.
