Hello,
I'm hoping for some expert advice on my roof woes.
Car is a February 2007 2.0l Sport. And the roof won't go up. I even tried popping some Viagra in the fuel tank but that didn't work.
The roof is fully down and all the roof warning lights are out. But press the button to raise it and the red light flashes immediately. I can hear a whirring sound which I take to be the electric motor but there's no movement suggesting that the hydraulics are knackered.
Microswitch at the rear of the shelf in the boot is in place and appears to be functioning.
Next problem. The red Bowden cable doesn't release the hydraulic pressure so the roof won't raise manually. I've given it a right old working out but I'm pretty convinced that it isn't releasing the bypass valve on the hydraulic pump. it's probably seized?
Any advice on next steps to take gratefully received. Although I suspect this may involve having to access the motor/pump and/or remove the soft top....
Thanks.
Ian.
Thanks.
Ian.
