Roof & window open/close function
Wyldie85
 Farnham, Surrey
Hi all,
Having just been out this morning I wanted the hood down...
Pressed the button, windows drop, hood goes down (red light goes off) keep the button pressed to put both windows back up and the drivers one did but the passenger one stayed where it was.
Thought it was just being odd, came back, did the same to put the top up and the drivers window closed, passenger one stayed halfway down.
Any solutions? Thoughts on this would be most helpful!
Dan
Have you tried resetting the windows?
Turn the ignition on
Push the open window button until the window is open, then keep it presses for 5 seconds longer.
Push the close window button until it is closed, then release.
Do the same procedure for both windows, this should reset the memory.
Doing a reset usually sorts the windows out :(
Unfortunately I am out of ideas, hopefully someone else might be able to advise you.
I appreciate the response! I thought it would be the fix I was after! I'm back to the drawing board! :|
