My roof will not open without the engine running. It also doesn’t work with the fob.
With the engine running it works perfectly.
Battery has 12,06 Volts.
I bought the car only a couple of weeks ago, so not sure if it was always like this.
Have the same thing on my 2011 2.31.
Bought a trickle charger from Argos £20 and I leave it on overnight once a week and then roof opens with key. Even after a long run it's often not enough to charge without trickle.
Therefore you must have a problem with the alternator not charging the battery or battery not holding the charge.
When i put my code reader on i was surprised the voltage show with engine running was 15 volts.
Have these cars been properly coded if they ever had replacement batteries.
If the car is several years old i thinking it's worth investing a new battery, just for the convenience.
A couple of weeks ago out of curiosity I put the battery on charge, and it took 10 amps... The car starts perfectly and I have no issues whatsoever. The car is used almost daily so maybe if I didn't.... It's a newish battery I think but food for thought maybe.
