I ibroker Member Mar 29, 2025 #1 With the rood down I keep getting a warning chime that the roof is not down correctly. Its intermittent and does not stay on. Any suggestions ?
T therealmc Member Mar 30, 2025 #2 Not sufficiently qualified to advise I’m afraid but welcome to the ‘club’. Love the car but have had a miriad of similar roof issues.
Chippie Veteran Wakefield Mar 30, 2025 #3 It’s probably a micro switch or a hall sensor, you could really do with having the car scanned to see what fault codes are present.
I ibroker Member Mar 30, 2025 #4 I had it scanned and because the light flashed on and went off quickly it left no trace apparently
J javis20 Active member Hershey, PA USA Apr 1, 2025 #5 It's probably one of the boot closed micro switches. You should replace booth sides. Very cheap and easy. https://youtu.be/qcwZC1uah_o
J javis20 Active member Hershey, PA USA Apr 1, 2025 #6 Also, you should get a quality scanner like Bimmergeeks ProTool. There are many more convertible top problems to come, like broken wires.
