Hi all, hope all is well!
I've recently had some issues with my BMW Z4's roof that hasn't been working of such.
The situation is as follows,
I've manually tried opening it using INPA but it does not work unless(!!) if I manually close the microswitch in the boot.
The metal hook is still there and there is an audible click when the contacts close so physically it looks fine.
When I put an object in the microswitch (closing the contact) strangely pressing close on INPA will fully operate the roof normally and lock it.
I can't seem to close it while the microswitch is manually closed (with the object placed earlier) so when I remove it and open the contact - INPA close function seems to properly close the roof.
All my error codes is just one at AUSSENTEMPERATUR (temp in German) at 12 GRAD C (Celsius).
Would this perhaps be a simple issue of replacing the microswitch and temperature sensor on the car?
Any insight would be greatly appreciated! Thank you.
- When the roof is closed - no lights/button pressed no response
When the roof is manually opened - red light flashing
When the roof is manually closed - red light flashing then after a while light disappears.
