While grovelling around in the boot of my recently acquired e89 I discovered that the roof pump is loose and just sat directly on the metal floor. Do I assume this should not be the case? Any help how how it should be would be gratefully received.
Angie4m said:Wow that looks properly manky looking in there. Mines was clean as a whistle. However the pump should not be loose but where is the insulating foam that was in there?
Tinker15 said:Agreed about the manky but it will get cleaned up! The rest of the car is excellent. Do you know how it should be fixed? The foam is AWOL!![]()
flybobbie said:Fixing kit is probably for all the cylinders.
My pump just sits in the foam loose.
Might be good opportunity to make sure you don't have a leak in there if recently acquired.
RobbiZ4 said:when completing your parts in the trunc, please have a look at the following story and get your pink relays replaced for about 30-40 bucks.
Tinker15 said:Thank you to everyone who helped with my pump problem. It now has new relays fitted and is tucked up in it’s new foam container.![]()
Smartbear said:Tinker15 said:Thank you to everyone who helped with my pump problem. It now has new relays fitted and is tucked up in it’s new foam container.![]()
Hi, how much did you pay for the replacement relays?
Tinker15 said:Smartbear said:Tinker15 said:Thank you to everyone who helped with my pump problem. It now has new relays fitted and is tucked up in it’s new foam container.![]()
£24.82 for the pair including delivery.
