Folks
I have posted on the problem I have with my roof not operating properly. I have replaced the pump/motor (and it’s located in the boot). As the roof closes (lifts) ok, it’s just really slow to open needing a push to get it moving open. I thought I had an issue with the rams, but after some advice from a forum member (number5) I swapped the pump pipe connections over, and then the roof opened correctly, but was slow to close, so the rams must be ok, and it must be the pump not pushing enough pressure out of the one port.
The roof disengages the front locks ok.
So here’s my first question. has anyone had the pump apart, as I thought the pump motor just rotated the pump one way to open, then the other way to close, just circulating the fluid one way then the other. Are there different seals in the pump as i thought it was just a centrifugal pump.
Second question, would the pump release plunger have an effect on movement in just one direction, or when pressed in does it effect both directions.
The plunger on mine isn’t stuck, it moves freely, although it’s not out very far (how far out should it protrude from the valve body?)
Al
Al
