Hi
I have a problem with the roof not opening, I dont think its the motor as I can hear the motor operate to open the latches any ideas on how to fix this issue..
When opening the roof I press the roof open button
Windows drop
Latches release, motor noise ends button solid red
Roof does not retract, when I lift finger of the button it flashes red.
I have checked the drainage channels they are clear, I've always cleared them regularly as always been worried that the motor would give up.
Rear parcel shelf is in lowest position, microswitch underneath appears to be working clicks when pushed in, I've not checked electric on switch as not getting yellow warning light.
Fuses are OK
Bowden cable does not appear to be working has some play in cable when pulled out the roof will not drop manually, roof moved back about 4 inches.
Is there an easy way of adjusting the Bowden cable as I think this is possibly the issue.
I did have someone rear end my Zed in November this was repaired at bodyshop through insurance, today was the first attempt at putting roof down as we are in lockdown the car has been off the road.
Thanks for your help
Windows drop
Fuses are OK
