Rustyspoon
New member
Hi Guys i hope someone on here can help me
My BMW E89 z4 2009 is currently in with the steeler as i brought the car from a vw garage with extended warranty so to claim the warranty for repairs it had to go to BMW, at the moment VW have agreed to pay for the repairs ( Thank god)
The issue is:
get in the car hold down the open roof button the windows go down and the first part of the roof starts to open around 25% then just stops, the roof will then will not continue to open or close, the only way is to take the key out then the roof will drop into the close position and if you hold the close roof position it will then lock.
The repairs so fair:
BMW have replaced
- Right folding top micros switch for panel 2
- Updated software and re config
- Replaced control unit module and re config
- the wiring has been checked and is all ok
- have checked the motor and there is no leeks and the Fluid in the hydraulic motor is showing the correct amount between min and Max
With the above repairs the roof is still not working with the same fault. I do not think they have a clue at this point and bill is getting longer.
any help would be much appreciated
The issue is:
BMW have replaced
