flybobbie said:Sounds like broken wire in roof.
As usual code reader will give some idea where.
Get you fav. drink spend the evening searching forum.
dumaurier7 said:I am experiencing the same thing but based on my cars history I am just going to replace the module now and add one more to a long list of module replacements! I had a battery catastrophically fail in the car, shortly after I started experiencing subtle and infrequent malfunctions which steadily grew in intensity and frequency over time. I already tried replacing the switch with a brand new one along with re-coding the module but neither provided a solution. The only thing that's weird is that the module does not report any errors when scanned!
Sorry for answering so late:flybobbie said:...anyone know what type of signal goes back to ctm. Wiring diagram quite basic. Could be voltage change or is it some bus signal.
flybobbie said:Thanks.
I took the switch apart and attached wires to circuit board and reinstalled.
Project was to use a remote control to open and close roof.
Then realised i needed to power module when car unlocked, easy i think, but needed ignition key in..
As we know we can open roof but not close with basic key fob.
Also does car need to detect someone in seat to operate close function.
That little project was abandoned.
Definitely not.flybobbie said:Also does car need to detect someone in seat to operate close function.
