Roof Not Latching When Down
dwoodford1987
York
Hi all
So ever since buying my 54 Z4 2.2 with a very low 164000 on the clock the roof will not latch when retracted.
Motor unlocks from the windscreen perfectly
Roof goes down perfectly
Motor re-engages when down to latch perfectly
HOWEVER roof doesn’t quite go down the final inch or so and we all know how important those inches can be so I have to give it a gentle push and can hear it clicking into the latch.
Any ideas as it is driving me mad. Also I have taken a video of it and can send it to people but I can’t upload it hear :(
Much obliged.
Hey,
I actually had the same issue, if you power the roof down without pushing it in manually and you go for a drive do you get the flashing red light on the console? it could be a number of issues, the main one being roof alignment - when I bought my zed the roof motor was fried so they sent it off to get it replaced by an indy before I purchased but when it came back it had the above issue due to the roof not being aligned correctly when the motor was replaced.
The fact that it latches when you push it in tells me that its not an issue with the latch so alignment would be my guess but there'll be some more technically gifted members who will know more than myself who will help im sure :D
Well it’s not off centre and it dead straight in line with the latch so not bent in any way, and the weather doesn’t seem to affect it. However if it has been latched down for a good few hours and then I put it up and back down it latches fine. It’s when it’s been up for period of time it doesn’t wanna go all the way down. I’ll work through the instructions and hopefully get it sorted.
Thanks for that :-) :thumbsup:
To be honest, it just sounds like the fabric is a bit stiff then. I know people have had success with the Renovo Proofer, as it conditions and softens the fabric too apparently. I can't speak from experience there, so will leave it for others to input.
Mine also does it, but drive 100 yards and it settles in - BMW actually completely removed the latch on the later models, presumably due to customer complaints. I can't come up on it's own whilst driving.
Mike
The lower catch was removed from late 06 onwards. The reason for this seems to be a combination of it beening a bit of overkill, the release button was a common rattle/squeak and it could also mark/wear away the roof lining. In light of this I removed mine nearly three years now and have never once had a issue because if it.
fairly common issue and could be down to a number of reasons - mine doesn't due to the fabric being slightly hard (maybe from bad washing, coatings, waterproofings etc) so doesn't fold where necessary to get it to lie flat and latch.
I fold mine down half way - push out the corners on both sides then goes down fine.
Bottom line is - wouldn't worry about it. Unless your red flashing light is on then something might be wrong in which case answers posted by previous messages above!
I'm actually going to be removing my latch this weekend for the reasons above.
As soon as you start driving, the roof will drop a little bit more anyway.
My latch has gone a bit corroded and you can see the nastiness through the rear window, hence me choosing to do away with it.
