Hello all,
I'm after an advice from you guys.
Short decryption in chronological order:
1. Bought 2009 Z4 in Sept 2024
2. Love the car, everything seems to be working, but roof stops after unlatching from the front, when button pressed again it keeps on opening.
3. Everything else is fine.
4. Feb 2025 big storms go through UK
5. Few days after storms passed, battery dead.
6. Managed to get to the boot, battery flooded, pump flooded.
7. Dry everything, recharge battery. Car lives again.
8. Pump motor is showing extreme fluid temp on the reader + error A696.
9. Replace pump motor and HAL sensor, no more errors. (Pump now much more eager than before).
10. Roof now stops with both parts on top, just after unlatching. Still no errors. You can close it back up.
11. I lost any faith that I will get this fixed and extremely disillusioned by German engineering (first no drain in the boot where battery and other electrics are, now the roof....).
12. Visually checked what I could, can't seem to find any issues.
13. The only thing I noticed is that all windows except driver's front show status open, drivers window shows state as it would be operating although it is fully opened.
Can drivers door window be the cause, reset it few times, opens and closes fine.
Can this be a problem with the wires that system is not discovering? I know roof unlatches from the front as you can slightly lift it with your hand.
Does anyone have any ideas? Finding a fault without any error is something that I feared the most.
Please help....
Please help....
