Roof motor
This is the one I got. Works a treat.
https://www.ebay.co.uk/itm/BMW-Z4-E85-Cabriolet-Convertible-Roof-Pump-Motor-2003-to-2009-Includes-Chamber-/274578168131?_trksid=p2349624.m46890.l49292
There are two types and you’ll need to replace with the same type. Some have a spacer chamber attached and some don’t
Just check you get the same one
The issue is when I got the carb it didn't have a motor at all ( car was getting used as a donor car by previous owner. Its got all the stuff in the boot been relocated.
I didn't know this! Every day is a school day 😊
You’ll be fine if you’re changing the complete pump and motor unit but not if you’re connecting a new motor to existing pump. That’s when you’ll need the correct match
I must have got lucky then, as it was just the motor I changed over. The one I fitted works a treat.
