So I've got an unusual issue I'm trying to resolve. Roof motor won't work, top unlatches then nothing.
Now I've pulled the motor into the boot. I've test run the motor with 12v from the battery, so I know it works...
So I've connected the motor back up to the wires in the boot and tried to operate via cabin and it doesn't spin. Is there any troubleshooting I can do?
The pump does need more hydraulic fluid, hence why I didn't test it fully assembled. So that's on my shopping list.
Anyone know what the culprit could be? Fuse?
Does anyone know what the fuses do? I checked this and found it could be 12 or 31 or 55? Does anyone know what respective fuses are for?
FYI, I've already removed the microswitch as a culprit. I tried to do it without the switch, and nothing happened at all. Then when connected and with the shelf, the top will unlatch. So I know the switch is working (and is pressed with the shelf).
Will the roof just not work because it senses no/low fluid? (didn't thinks so, but thought I'd double check).
Any feedback or suggestions welcomed!
