Roof motor relocate in Staffordshire - STUCK!
enuff_zed said:
Try pulling it straight up. Eventually it will either snap the tie or the fin.
You would think so. Have managed to clamp some grips on it and then yanked up and down from the passenger side, drivers side, the boot for about 20 minutes. Nothing.
bigwinn said:
Get over here I’ll sort it for you
Tempting. Am going to try and lever it with a mini crow bar from behind the passenger seat but failing that I might take a trip to see you. 2 hours each way but thats worth it!
Be very careful you don't slip and damage something or break a hydraulic line.
I am in work tomorrow 9-5 with no annual leave left unfortunately otherwise I would be taking one of you up on that offer.
Might have another go tomorrow but I cant see this cable tie breaking or me being able to cut it.
I had one last go in the dark and rain.....
Its out.
Whether I have broken the roof in the process we will worry about tomorrow when I put everything back and test it. Thats tomorrows problem.
In the end - I stood at the passenger open door facing forwards and reached my right hand back and in behind the passenger seat. I had grips clamped on to the edge of the lower case (nearest the boot) and pulled up really hard. A few cracks later and I was able to pull it through the boot. I had snapped the casing mount and the cable tie.
Thanks for all the helpful comments. I would have given up otherwise.
I also came very close to coming up to Lincoln tomorrow morning and ditching work!!
Well done!
Hopefully all good now.
Once it’s in the boot stand it upright and fill to spill with jack oil, otherwise the extra angle may uncover an inlet port and it will suck air.
I am free tomorrow so I’ll PM you my number in case you need any other support.
All sorted finally!!
Needed to add more oil to the system given the new location - something I wasnt aware of so thanks to [ref]enuff_zed[/ref], for that heads up or I would have properly stressed when the roof went down ok but then refused to close again until I added more oil.
Thanks to all for your help.
Well done for persevering.
Permission to feel smug.
Update on this if anyone wants entertaining...
So the roof has been working fine. Have used it lots.
Then today it failed to come up. Had a look and saw that the hydraulic reservoir was on minimum. Oh dear - a leak?
So I topped it up again just to see. Roof went down and back up no problem although didnt sound the best. Checked - hydraulic fluid low again. Damn.
Got a torch and looked through the rear window and into the well where the motor used to sit and I see a nice deep pool of hydraulic fluid. Perhaps I nicked a line moving the motor after all. it does explain the slight sloshing sound I have been hearing from the cabin!
Have managed to extract the leaking fluid. I guess the next challenge will be a full roof remove to try and get to the lines to fix them. Is this a DIY task or should I cut my losses and stomach a repair bill? The car is a daily driver which is frustrating.
Kind of wish I had not bothered to move the motor now and just taken my chances with the drain valve.
Don't panic!
I don't believe this is a full roof remove and possibly quite simple now the motor is moved.
In all likelihood it is the lower hose on the left ram, which has a 90 degree bend near its end and will have been sitting in the water quietly corroding away.
I have a pipe if you need it. Possibly best to change them both while you're in there.
Best bet is to talk to Alan ([ref]Number5[/ref]) who is an expert at accessing these and can offer advice, or sort it for you if you're happy to drive to Bristol. He should see this referral, but I'll message him a heads up as well.
Have you reached this conclusion based on my description of the fluid being dumped into the motor housing well?
Might have to take the plunge and drive down to Bristol if its not something I can tackle myself in a day or less!
Will wait and see what Alan says but thanks for the response.
Yes, it's a common weak point.
Alan has replied to me so should be along shortly. :thumbsup:
I suspect Alan will have the pipes as well.
