Hi All
I have a connection issue on the bottom of the roof motor that should be simple to fix, but is being a PITA. Simply put, one of the female spade connectors keeps working loose and needs to sit in a very particular place in order for the motor to work. I check the connector is clean and a snug fit, open the roof and go for a drive, then the roof won't go back up until I push/pull/fiddle about with the connector again. Of course it's the terminal that sits against the wall and not the exposed one I can see.
Odd thing is, the motor was relocated to the boot over a year ago and has worked perfectly and has not been messed with since relocation.
Anyway, enough rambling, my question is, in order to check the motor fixed terminal is secure, I could do with the motor being out so that I can get a good look at it. Is the motor removal from the hydraulic reservoir as simple as removing the two Allen bolts and pulling apart? Will the fluid leak out? Are there other bits that will fall out?
TIA
Lance
TIA
Lance
